98 v70 awd erratic fuel level indications
lowufo777
Year and Model: V 70 awd 1998
Post by lowufo777 »
Hi Everyone
fuel gauge is reading incorrectly and drifting down then back up ??question where is the sending unit located on this car and how do I go about fixing it
Thanks
M
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
Try a bottle or two of Techron in the next 2 tanks of fuel to see if you can free up that sticky sender.
The sender is in the fuel tank, which requires dropping the tank out of the rear, or cutting a hole in the floorboard of your car to access...
There are also 2 sides to the tank on an AWD, each with a fuel sender unit. They are "added" together in series, so if one is not reading due to a sticky sender and/or wiring problem, the gauge will read off.
'98 S70 T5
2016 Chevy Cruze Premier
jimmy57
Has thanked: 5 times
Been thanked: 322 times
Post by jimmy57 »
Agreed. deposits on the resistive surfaces can be addressed by cleaners. Cheap try with no downside.
