2004 XC Radio/electric problem
moosehead
Year and Model: xc70 2004
Post by moosehead »
2004 xc70-
I am having an intermittent problem with my radio,hu613, and some electronics. Every once in a while the radio display will show garbage. The radio still works fine, I can change stations and everything. The display just shows garbage and does not change. Turning the radio off and on again doe not fix it.
The only way to fix it is to turn the car off and start it again.
I also noticed that some times my cruise won't work when this happens with the radio. If the cruise is on it works, but if not I can not engage cruise. I press the button and the cruise light comes on but it does not engage.
Not sure if this is related but the passenger front lower speaker does not work.
Any ideas on what this problem could be?
Has thanked: 1613 times
Been thanked: 4078 times
Does the message center show the same gibberish? It might be a CAN communication problem between modules.
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
Naw, radio is going south
If it only plays Alan Jackson, it's gone south.
....drive......
