replace a turbo with a used one? and get the software right? Topic is solved
Bullitt187
Post by Bullitt187 »
Well My turbo has finnally packed it in, and to make matters worse I found a used one for $100 dollers but am beiing told that it will most likely not work due to the difference in software? I have to match the part numbers or something like that, does this make sence to anyone?
Guest
Post by Guest »
it is a 1994 850 by the way
White850Turbo
Post by White850Turbo »
So long as the turbo came from a '94 or '95 850 turbo w/ the conical flange outlet, there should be no problems with fitment.
-Sean
1998 S70 T5 (Almost Stock)
robert213
Post by robert213 »
ECU Software Update is only needed if you install a larger turbo or intercooler. Forget buying a used one.
Have your current turbo rebuilt professionally. It shouldn't cost much more than $300. Remember to use a new turbo oil feed line. Shop and Compare, starting with Forced Performance...
Volvo owners have been recommending...
http://www.dallasturbo.com/
Majestic Turbochargers of Dallas
1000 S. Wildwood
Suite 10
Irving, TX, 75060
http://www.hirschinds.com/
HIRSCH FOREIGN
P.O. BOX 18063
PHOENIX, AZ 85009
Mitsubishi owners use...
http://www.turbochargers.com
Turbochargers.com
5410 Burr Oak Drive
Houston, Texas 77092
Tech Line: (713) 681-1111
Order Line Toll Free: (800) 749-7111
Fax: (713) 939-1111
Email - [email protected]
http://www.forcedperformance.net/
Forced Performance
671 New Hope Road West
McKinney, TX 75071
Phone: (972) 984-1800
Fax: (972) 984-1802
[email protected]
[email protected]
