IPD sale Volvo Parts
when buying a used ETM what will work without a reprogram?
Do you have a failing Electronic Throttle Module? What steps to take if you do, plus the latest ETM news. Volvo 1999-2002 models only please.
regent
Year and Model: 2015 XC60 T5
Has thanked: 1 time
Been thanked: 5 times
United States of America
Re: when buying a used ETM what will work without a reprogra
Post by regent » Tue Aug 26, 2014 11:39 am
Then, if you don't like the fun of intake removal to do the PCV, you wouldn't buy a Bimmer either, what a pity! :lol:
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 non-turbo - lovely!/used to be... Now retired :(
1987 340 DL (with the 4-cyl N/A Renault Diesel engine, 5-speed manual, RWD) - sold (I wish I did not have to...)
Cal1972
Year and Model: 2001 s80 t6
Post by Cal1972 » Sun May 08, 2016 11:13 am
doublebug wrote:Supposed that you have DiCE.
I will give you my program that shares DiCE via internet.
You install new ETM but connect to the socket an old one.
Connecting DiCE to the car.
Plug to laptop. (Off course it should have internet connection)
Initiate connection to my server.
I will read firmware.
You connect new ETM to the socket.
I will save it's firmware too.
After that I will upload software from your old ETM.
You can check how car is working.
I can check using VIDA if there is any error codes stored and clear them.
So everything is doable.
If you decide that new ETM does not help I will restore it's firmware and you can return it back.
Just ensure that you have fully charged good battery before starting.
Hi Doublebug do you have the software to reprogram 2001 s80 t6 ETM? I bought a used one they say it needs to be reprogrammed thanks
doublebug
Year and Model: XC90 2007 D5
Been thanked: 3 times
Belarus
Re: when buying a used ETM what will work without a reprogram?
Post by doublebug » Mon May 09, 2016 3:44 am
If you have and old one that worked properly in the past I can transfer software.
Or post your ECM software numbers and I will check my database.
If you have questions about Volvo firmware ask me. I may know an answer :)
lpl258
Year and Model: 2001 v70 xc awd
Post by lpl258 » Sun Jun 17, 2018 9:46 am
doublebug wrote:
Mon Jul 14, 2014 2:03 pm
Hello good sir, ive been lurking this thread for a few days reading and such. I have spent months trying to negotiate this ETM dilemma on a very tight budget. You are doing gods work because this I believe, is exactly what I need. Ive a dice unit shipping in and truly look forward to hearing from you. I don't know what time zone you are in, but ill awake in the middle of the night or such, so it is convenient for you, to perform exactly as you described.
Leo 1-757-529-1032
USA
steveneedsmoney
Year and Model: 2001 s60 2.4t
Post by steveneedsmoney » Thu Nov 08, 2018 3:00 pm
Is Necowafer or Doublebug still around? I sent a PM to each, it says the PMs are in my outbox but not sent?!?!?
steveneedsmoney
Post by steveneedsmoney » Thu Nov 08, 2018 3:01 pm
Where do I get the ECM software numbers??
precopster
Year and Model: Lots
Has thanked: 3 times
Been thanked: 68 times
Australia
Post by precopster » Thu Nov 08, 2018 4:08 pm
Read them with Vida/Dice in Network menu or get a handheld scanner that can do this.
BTW usually only an expensive garage scanner can do this apart from Vida/Dice
Current cars:2002 XC70, 2001 V70 T5, 2006 XC90 2.5T, VW Transporter 2.5TDI
www.precisioncarmodules.com.
rodkenney
Year and Model: Volvo 1999 V70R
Post by rodkenney » Mon Nov 12, 2018 8:56 pm
Have you gotten a response yet?
steveneedsmoney
Post by steveneedsmoney » Thu Nov 15, 2018 10:35 pm
Ya I did!!!
robbiewilso
Year and Model: V70 2000 XC SE
Has thanked: 1 time
Post by robbiewilso » Thu Dec 27, 2018 6:05 pm
So I had an original ETM with over 100k miles and the ETS light started coming on intermittently. I bought a used one for my V70 that was already rebuilt with a magnetic sensor xemodex retrofit. When I switched it the light has not come on again and there were no symptoms of ETM failure (idle surge etc) Ran great for a month or so. NOW I have P1238 code come on and poor running with the MAF plugged up or unplugged- Idle is horrible and of course I get a MAF P0102 code when the MAF is unplugged. I think there is a bad vacuum leak that I cannot find yet; planning on doing a smoke test this weekend. Any advice from VolvoLand? Thanks!
Who is online
Users browsing this forum: No registered users and 5 guests
