99 s70. Where to find a used climate sensor?
kmg108
Year and Model: 1999 S70 T5
Post by kmg108 »
Me again. This board seems too good to be true. I have an issue that I strongly suspect is a failed interior climate sensor. I have no heat on the driver side, but it appears the dampers are working properly. I would like to test a replacement cabin sensor, but do not wish to pay $100+ for the part unless I know for sure that is the problem. The little fan inside my sensor never seems to turn on anymore. I have sprayed it with sensor cleaner and blown it out with compressed air. Does anyone have a working one of these that I can buy or rent for testing purposes?
Thanks!
Has thanked: 1611 times
Been thanked: 4075 times
Sounds like a pick and pull candidate. Post up a WTB and be friendly with the folks who love the junkyards and ye shall be cooled....
kahl
Year and Model: 2000V70XC
Been thanked: 10 times
Post by kahl »
I am visiting a boneyard tomorrow, tell me where this sensor is and I will pull one for you. they just got in a 2000 V70.
deepsouth
Year and Model: 2001 Volvo XC70
Been thanked: 11 times
Post by deepsouth »
I bought two from a local PNP and within two months both are now shot, resulting once again in the double flashing lights and no ACC. :(
2000 S70 GLT SE, 175,000
2001 XC70, 129,000
Has thanked: 2210 times
Been thanked: 1852 times
The sensor should be behind a little grille to the left of the ECC unit. To access you need to pull the radio and the ECC unit (radio by popping out the 2 tabs by pushing in to release and then pull it out using the 2 tabs). ECC is easy to remove also, tip it up slightly from underneath and give it a good push forward out of the dash.
Feel behind the dash and pop the switch out to the left of the little grille.
To remove the sensor is a little (make that a lot) difficult. There are 2 tabs just off the 12 and 6 o'clock (clockwise looking at the front) that need to be depressed to remove. It is easiest to do after removing the connector first.
