90 240 dl sedan. cannot find a cold start valve replacement.
r_ziots70
Year and Model: 240 dl 1990
Post by r_ziots70 »
I've searched every where and cannot fiind a cold start valve or injector for my car. Min isn't acting right and its leaking. If someone has any recomendations I would be greatful :-)
93Regina
Year and Model: 93:240/940
Been thanked: 65 times
Post by 93Regina »
r_ziots70 wrote:cold start valve or injector for my car.
I checked VADIS, parts, and no part number is shown. If there is a part number, try googling it.
I don't know if an injector shop could run cleaning fluid thru it; it could be done yourself: how to clean your fuel injectors (correct way).
lummert
Year and Model: 760 1988
Been thanked: 26 times
Post by lummert »
Part number: 3517130. Everything I find says it's no longer available. Time for a walk though a junk yard for a used one?
1988 Volvo 760 Turbo Wagon
lummert
Post by lummert »
Standard Ignition Fuel Injector Cold Start Valve part number CJ10 is an OE quality replacement.
93Regina
Post by 93Regina »
lummert wrote:Standard Ignition Fuel Injector Cold Start Valve part number CJ10
If a barbed banjo fitting could be found in same diameter as this Bosch 0280170032 (CJ50 ), chances are, this would work also.
I've used carb cleaner, and compressed air to clean up injectors...have to pulse voltage to injector...
jimmy57
Has thanked: 5 times
Been thanked: 322 times
Post by jimmy57 »
Delete it.
The models with that flooded in super cold temps and most with the vavle do not have software that ever grounds it to operate.
93Regina
Post by 93Regina »
jimmy57 wrote:Delete it....ever grounds it to operate.
His must be a working unit, since the pintle is leaking, or something is grounding out unit; pull plug.
Gates Barricade Fuel Injection hose comes in different diameters; 225 psi working pressure rating
Bosch 0 280 155 746 Injectors are same lb rating as OEMs, and these are third generation Bosch; I'd consider coverting OEMs if cold starts become an issue, if cold start valve is removed.
r_ziots70
Post by r_ziots70 »
sorry didnt have internet for along time. just now gettin back on here. still have the same issue. cold start injector is leaking. no junkyards to scavenge from. will however if we cant get the right part. take your advise to switch to bosch. can you give me a specific # on that bosch please? oh and we just found out the computer has been bad before we owned the car. the person who owned it forgot to tell us that. we live in a warm envirionment. do we really need that stupid injector??
