850 fuel mileage problem
chrisjm91
Year and Model: 95 Volvo 850T5
Post by chrisjm91 »
My 95 850 turbo no mods is not getting the mpg's that it should. My last 850 was a 96 non EGR And it took me from Virginia to Florida on one take of gas and could ride around town most of the day without noticing the gas gauge move. But my current 95 850 W/EGR guzzles the gas. Now I had the engine replaced with a used engine with low miles and had them replace all the essentials while they were at it ; timing belt & pulley, water pump & many other odds & ends. So where is my gas mileage going? Fuel filter or pump, egr valve, dirty air filter, pvc system, injectors or what do you think? Please help thank you!
RussB
Year and Model: '00 S70, '04 S60
Has thanked: 3 times
Post by RussB »
Let's start with the basics...How many MPG's are you getting?
'00 S70, '04 S60 and the never ending quest for Stage Zero
chrisjm91
Post by chrisjm91 »
On my dash, its averaging 14 to 16 on a good day...
RussB
Post by RussB »
Read the DTC codes and report back...
https://www.matthewsvolvosite.com/read-codes-volvo-850
chrisjm91
Post by chrisjm91 »
I own my own obdII system, and the only code ever thrown was an "EGR Flow" code. And that didnt happen until I removed the intake manifold for cleaning. But the gas mpgs were down before that. Im sure the egr flow isnt helping.
chrisjm91
Post by chrisjm91 »
I did not see this code in your link and I have the car apart cleaning the pvc system right now so I cant plugIthe obd2 scanner to it right now. But thats all the code said ""EGR FLOW" no more no less, and im pretty sure it was po400 but like I said I didn't find that in yoir link.
