1994 850 Speedometer
I'm trying to fix my 94 volvo the speedometer won't work. I am looking to buy a used instument cluster for it, the question that comes up from the sellers is to check with my local volvo dealer to see if it needs programing. I don't have a local dealer closet is 100 miles away. So I'm looking for some help. Do the need programed?
shaker_chi
- Year and Model: 94 850, 98 S70T5 M
- Has thanked: 3 times
- Been thanked: 3 times
In 1994 Volvo used 2 types of instrument clusters. Follow this link, gives a ton of details. Not sure why the dealer would need to program it though.
http://www.volvoclub.org.uk/tech/servic ... edures.pdf
http://www.volvoclub.org.uk/tech/servic ... tPanel.pdf
- Year and Model: Many Volvos
- Been thanked: 76 times
There is a kinda dealer programming to set the mileage in the cluster memory. You can do it yourself but it only works once per cluster and it doesn't actually change the indicated mileage on the odometer, only in the cluster memory. There are some other regional settings like miles and km but if you get a compatible domestic cluster it should all be good to go.
shaker_chi
Lee, Are you speaking of the mileage stored in the ECU? I have a 94 and I don't see anything that needs to be programmed.
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Nothing needs to be programmed for the cluster to work.
The stored mileage in the ECU is a misnomer. It never actually is stored in the ECU, it is stored in the cluster and that is what you can reprogram. The provision is there in diagnostic mode four or five (I'm at the cabin and the book is back at home) and it was created so that the dealer could match the stored mileage in the event that the cluster needed to be replaced. It is all done with the DTC button box so it doesn't require anything special other than the codes.shaker_chi wrote:Lee, Are you speaking of the mileage stored in the ECU? I have a 94 and I don't see anything that needs to be programmed.
They are interchangeable - sort of. The trip information module doesn't work with the Yazaki.
What did you have before?
- 1972 Views
Last post by marcsanders
- 13 Replies
- 7289 Views
Last post by esl_97_850_T5
- 1247 Views
Last post by 95850turbowagon
- 753 Views
Last post by rspi
- 560 Views
Last post by bugs11
