I've read through all the posts I can find but am still stumped.
240 (244); new battery (good), 3rd alternator (good, this one tested before I purchased)
voltage on B+ post matches battery voltage, usually 12.2-12.6
Same voltage on D+ (not running, key on)
Perfect continuity between B+ and battery positive
Perfect continuity between alternator casing and battery ground post
Key on, not running, battery light on dash is on, goes off when running
I've run a direct ground from the alternator case to the ground post of battery
I've run a direct hot from B+ to battery positive
So, to summarize, 12v coming through exciter wire, good ground, good continuity from B+ to battery hot post. What's left?????
88 240 not charging, checked all i can think of
- 93Regina
- Year and Model: 93:240/940
- Been thanked: 65 times
Leave those hooked up, and run another wire from exciter to + battery.cbarth wrote: I've run a direct ground from the alternator case to the ground post of battery
What's left?????
I'll assume 12 gauge wire is being used for all three wires..
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
With engine running check with voltmeter between case and block, should be 0.2V or less and between + lug and battery + terminal and should be less than 0.3V.
Continuity with ohmmeter will get you in trouble on high current carrying wiring. 2 strands of wire connected out of 64 strands in the wire will give you continuity but have HIGH voltage drop.
OK. I removed all 3 wires from the alternator. Ran a ground from the case to the battery negative and then 2 direct lines, one from B+ and one from D+ to the battery hot post. No change.
I then reconnected everything and measured voltage while running. Battery 12.3, D+ (exciter) 12.5, B+ 12.7
I know anything is possible but could this have an external regulator somewhere that could be preventing the voltage from exceeding a certain amount? If that were the case, I would think that the voltage would be consistent though, meaning the battery would always read 12.2 or 12.6 or whatever...
- 93Regina
I hope engine RPM was increased....cbarth wrote:while running. Battery 12.3, D+ (exciter) 12.5, B+ 12.7...
1990 ELECTRICAL Alternators & Regulators
yes, rpm was increased
just walked past the car and for some reason thought I'd check voltages while it was sitting. I check across the battery, battery hot to block, battery hot to alternator case, B+ to block... All 4 measured 12.97
- 93Regina
I realized alternator was "checked," but have them check it again, with your voltmeter.cbarth wrote:... All 4 measured 12.97
Otherwise, 1990 ELECTRICAL Alternators & Regulators
its actually the third alternator. I replaced it, same results so returned it. Same results, argued with them to get a third one and had them check it before i left. i stood there with a meter and it was putting out 14.5
There are two items mounted to the firewall next to the battery. no markings. One of them is a rectangular silver "box' about 2 inches wide and an inch and half or so tall. It has I think 5 wires going into it. There is also a thin black box with some red wires going into it, one of them pretty good sized.. any chance one of them (the silver one mainly) could be an external regulator? I'm trying to post pictures but can't seem to get them posted.
- 16264 Views
Last post by Richard99
- 12 Replies
- 2785 Views
Last post by brushhippie
- 30 Replies
- 4904 Views
Last post by polskamafia mjl
- 2297 Views
Last post by popphl
- 1098 Views
Last post by cn90
