Did you know? 🤔
whats to be gained from R manifold on s70 T5?
How to go faster, stop quicker, and turn harder. Chips, exhaust, larger turbos, bigger/slotted/drilled rotors, high performance brake pads, manual boost controllers, performance shocks/struts/springs, airbox mods and more! Also discussion on HID and Xenon lights, aftermarket foglights and other exterior lighting.
s70gltnewbie
Year and Model: 1998 S70 GLT
Has thanked: 0
Been thanked: 0
United States of America
s70gltnewbie
Re: whats to be gained from R manifold on s70 T5?
Post by s70gltnewbie » Wed Feb 12, 2020 8:27 pm
s70gltnewbie wrote: ↑
DIRECT PATH OF EXHAUST PORTS TO DRIVE THE TURBO IS MUCH MORE EFFICIENT THAN THE LPT OR EVEN OLDER T-5 TYPE.
Will an R exhaust manifold bolt up to a glt with no problems?
FLXC90
Year and Model: 98 V70 T5
Has thanked: 2 times
Been thanked: 12 times
FLXC90
Post by FLXC90 » Fri Feb 14, 2020 9:34 pm
Will an R exhaust manifold bolt up to a got with no problems?
Yes It will also bolt up to the GLT. Your LPT engine uses the same exhaust port and turbo mounting configuration as the later "R" manifold, which became the 2.5L turbo manifold. It uses a different runner design, but mounts the same. Some say the power gains aren't significant on otherwise stock setups. There is a possibility that it may reduce the incidence of burnt valves due to improved scavenging, and it sounds a little different than the earlier manifolds. Look for one in any 2.5T equipped S60, V70, XC70, XC90 .
Current Volvos:
