IPD sale Volvo Parts
Did you know? 🤔
08 XC90 Brake caliper torx bolts
Help, Advice, Owners' Discussion and DIY Tutorials on Volvo XC90s. The XC90 proved to be very popular, and very good for Volvo's sales numbers, since its introduction in model year 2003 (North America).
dnwong
Year and Model: 2008 xc90 3.2
Has thanked: 3 times
Been thanked: 0
United States of America
dnwong
Post by dnwong » Sun Aug 10, 2014 12:51 pm
I accidentally loosened the torx bolts holding the two halfs of the front caliper. Its a big torx T55? Anyone know the torque spec to re tighten.
gntl2000
Year and Model: XC90 2009
Has thanked: 0
Been thanked: 0
gntl2000
Re: 08 XC90 Brake caliper torx bolts
Post by gntl2000 » Mon Aug 11, 2014 5:54 am
I have an '09 but the year should not matter. Those aren't Torx bolts. A 7mm Allen (aka Hex) socket is what you need torqued to 30Nm.
2009 XC90 V8 AWD - R Design
2000 V70 5spd manual - crossing into the 300,000 mile club
arfstrom
Year and Model: 2005 XC90 T2.5
Has thanked: 0
Been thanked: 0
arfstrom
Post by arfstrom » Mon Jun 06, 2016 9:20 pm
My O5 XC90 uses Torx 55. I would have appreciated it if had been allen (hex), it would have saved me a trip to the Menards.Then after that trip, It wasnt' the bolts that I needed to take off. There was a 14mm that was what I needed.
(more for the random googler, like me, that was looking for this information prior to running to Menards.)
amadeov
Year and Model: 2007 Volvo XC90 V8
Has thanked: 0
Been thanked: 0
amadeov
Post by amadeov » Fri Oct 21, 2016 1:40 pm
Both bolts are present on all 2003-2012 XC90 front brakes. There are two 7 mm Allen/Hex bolts (which are also the caliper pins) that are located underneath the plastic protective coverings toward the upper center of each front caliper. There are also four T55 Torx bolts that hold the front half and the back half of the caliper together.
Guess who has been working on his front brakes and suspension on his 2007 XC90 V8. :lol:
pgill
Year and Model: 2010 S80, 2008 LR2
Has thanked: 11 times
Been thanked: 18 times
pgill
Post by pgill » Sun Jul 07, 2019 12:33 pm
My Audi uses ATE calipers and I removed the T55 so that I could upgrade to the larger S4 rotors.
At the time my research indicated that I should use about 60 ft*lbs.
So that is what I did.
However I checked the T55 bolts based on your question and I discovered the following
M12 x 1.75 grade 10.9
The 10.9 is a higher grade steel that can handle more torque
My original research was appropriate for a grade 8.8 bolt
For the 10.9 the torque rating is much higher about 97 ft*lbs for a zinc plated bolt
https://www.imperialsupplies.com/pdf/A_ ... Charts.pdf
I’m going to check my T55 bolts and if they are loose I will post again
I am going to increase the torque to 70 ft*lbs
Good luck
Paul
pgill
pgill
Post by pgill » Sun Jul 07, 2019 2:34 pm
Follow up
Everything was still tight
I set the torque wrench to 40 ft*lbs and it clicked without moving the bolt
Raised the torque to 70 ft*lbs and the bolt did rotate but only a few degrees
I’m happy with 70
Take care
Paul
SuperHerman
Has thanked: 0
Been thanked: 98 times
SuperHerman
Post by SuperHerman » Sun Jul 07, 2019 4:19 pm
I am going to throw a word of caution out there. Strongly suggest one sticks with the specs.
Torque by bolt hardness ignores the other half. The bolt can tear the threads out - just something to be cognizant of, especially with Aluminum. Rotors are pretty robust.
pgill
pgill
Post by pgill » Sun Jul 07, 2019 4:34 pm
SuperHerman,
You are 100% correct
Thanks for pointing that out
The 12 mm T55 steel bolts mount the aluminum half of the caliper to the cast iron part of the caliper
The Aluminum is not threaded it is held in compression by the 12 mm bolt
The female threads are in the cast iron part of the caliper
The correct torque should be due to the cast Iron
Maybe 60 ft*lbs is a good torque
Good discussion
Thanks for your input
Paul
pgill
pgill
Post by pgill » Sun Jul 07, 2019 8:26 pm
Hopefully a picture will help
Red side of caliper in the picture is Aluminum
Dark brown side is cast Iron
Four T55 M12 bolts hold the two sides together
One of the bolts is visible in the picture
Thanks
Paul
pgill
pgill
Post by pgill » Mon Jul 08, 2019 8:39 am
All,
I found another link with a recommendation for a M12 Bolt going into cast Iron
Note: if you look at the chart the recommendation for Aluminum is significantly lower which is consistent with what SuperHerman pointed out
https://www.allpar.com/fix/body/fasteners.html
Based on this I am comfortable with 70 Ft*Lbs
Take care
Paul
