2009 XC70 Bent Crossmember/Subframe/Engine Cradle
Glengo
Year and Model: XC70 2009
Post by Glengo »
I recently purchased a 2009 XC70 at auction. It had sustained a side impact that pushed the left side wheel in snapping the steering knuckle where it holds the tie rod. I purchased a new knuckle and started to replace it when I discovered that the subframe is pushed in and up about 3/4 of an inch where the control arm connects. I called a local shop and they quoted me $3,500 just for the labor to replace the subframe. I found a used one for $500. My question is, how difficult is it to replace? Also, should I have a frame shop attempt to bend in back into place?
Has thanked: 1611 times
Been thanked: 4072 times
I'm sure you can get a subframe replacement procedure from Volvo but no one will advise you on straightening a subframe, unless you are a professional collision shop. Frame straightening isn't uncommon in the business, but I know nothing about sub components.
jimmy57
Has thanked: 5 times
Been thanked: 322 times
Post by jimmy57 »
That shop is VERY high on that repair.
Call a body shop and get a price. That is a rare repair for a mechanical shop but a common repair from a wreck performed by a body shop.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
It shouldn't be too expensive to replace the subframe, but it does take a couple of hours, given the steering rack also must be disconnected and the engine supported. I'd say around $5-$700 should be a fair price and indeed a body shop is the best place to do it.
