-99 S80 T6 got BAD after Sacer TPS
So I decided to replace the TPS in my ETM because it was throwing a P0121 code after some driving and would occasionally go into limp home mode. The mounting went good I think and now when I start it the triangle and emissions light comes on with the ignition on. I start it as normal and it goes good for a couple of seconds before starting to shake horribly. If I try to push the gas pedal it doesn't go over 1200rpm. Still throwing a P0121 code.
Still have no clue why It doesn't work. I've connected it and checked voltages on the pins and its at 0.5V at fully closed, 1.2V at idle open and 4.5V on fully opened. When I turn on the ignition it just sits there, and when I shut it off it moves to fully closed for 5 seconds before going back to idle position.
EDIT: Heres a video showing how it runs.
- 1493 Views
Last post by precopster
- 3973 Views
Last post by bmdubya1198
- 1894 Views
Last post by RickHaleParker
- 2326 Views
- 3110 Views
Last post by vtl
