'96 Volvo 855 Platinum Wagon - Turbo, Stock *SOLD*
burnout8488
Year and Model: 1999 S70 AWD
Post by burnout8488 »
1996 855 Platinum
Mileage: 187,506
Purchased around 186,000 in October 2013.
I have done in the last 6 months:
  • PCV System
  • Bosch front O2 sensor.
  • New OE Volvo cam seals
  • Updated dipstick and dipstick tube
  • Coolant reservoir w/Volvo blue coolant
  • Volvo OE battery
  • Volvo OE Exhaust system w/ new tip
  • Turbo removed, cleaned, new Forge CBV, new black silicone boost & vac lines. 100K mile TCV installed.
  • Replaced all blown interior bulbs, including armrest storage pocket, glovebox, and 12v outlet illumination.
  • Repaired heated seats, both function flawlessly.
  • Homelink Visor
  • GROM Bluetooth integration with audio streaming and call capability.
  • Rear rotors w/Akebono Euro Ceramic Pads
  • New e-brake hardware, works perfectly
  • OE Volvo Fuel Door Hinge
  • New Walbro fuel pump
  • OE Behr blower motor
  • A/C compressor clutch shimmed
  • New headlight wiper washer check valves and V70 headlight wiper arms. Both systems work 100%.
  • V70 XC roof rails
  • OE Volvo license plate brackets and front plate bracket spacer
  • 850R ECU for 10.9psi.
  • Upper & lower tailgate rubber trim strips
  • Volvo 960 Steering wheel & airbag
  • Little fender blinkers
Previous owner & past owner:
  • IPD front and rear sway bars
  • New rear self-leveling Nivomats w/new shock mounts
  • Rear trailing arm bushings
  • OE TRW tie rod ends
  • Sachs front struts
  • Lemforder control arms
  • Rebuilt front calipers w/Volvo OE pads
  • A/C Evaporator replaced and many cabin filter changes
  • Bosch Alternator
  • New Ignition switch
  • IPD Sway Bars
  • New Volvo wiper arms w/Bosch blades. No rust, looks great.
  • New Volvo oil cooler and transmission cooler lines
  • New Valeo OE radiator
  • New OE upper spring seats, bearing plates, and hardware
  • Front axles
  • Meyle HD sway bar links
Never been tuned, steering is super tight and only OE parts (except the Meyle HD sway bar links and front axles) have been used on the car. It’s been garaged full-time and hasn’t seen Winter at all under my ownership. I will include the original 10psi ECU as well. Climate control works flawlessly with no error codes, A/C is perfect. Set it to AUT + 72º and it’ll do everything for you. An absolutely ridiculous amount of money has been put into this car and it drives like it. The steering is tighter and sharper than any P80 car I’ve ever driven, and the engine is super smooth and quiet with the new exhaust system. Every single thing in the car works, every bulb works, every function works. Boost comes on just like it should, and the Forge CBV makes a nice little sound when you let off.
Back to the A/C, yes, it's perfect. There are no leaks. This isn't a system that needs a "top up" every few months. A/C systems should be sealed, if they need a top-up, they're leaking. This one doesn't. The pressure is absolutely dead-on what it should be, and has held that since the evaporator was serviced years ago under the 1st or 2nd owner's care.
The condition is probably 8.5/10 if I had to rate it. The front bumper has some low scuffs, and the tailgate has a few touchups under the rubber trim that poke out a little bit. Overall, it's gorgeous and the paint has been well taken care of by the previous owners. It's clear that this was never a beater car, because the interior is amazing for its age. The wheels were all professionally powdercoated, and only one has a ding on one of the spokes from a careless tire shop. Other than that, the wheels are flawless.
Reason for sale? Got a 2013 VW CC and need my ’99 for winter/road trip duty. There just isn’t room in the garage for a car that will barely get driven anymore. I have the previous owner’s service history that includes most of the things I listed above but has dates and mileage - available via e-mail.
This is most likely the finest Platinum 850 on the market right now, and out of only 500 built, there aren’t bound to be many more like it. If you want reliability but love old bricks, this is the one. Come check it out, and I'll give you the grand tour.
Price: $5300
E-mail or PM me with any questions, or additional photo requests. The car is located in Endwell, NY. NYS inspection valid until October 2014.
'13 BMW X1 35i M-Sport
'99 S70 AWD/FWD - 198K - FOR SALE!
burnout8488
Deposit received. Treat this as sold.
