1990 740 upper and lower heater core hoses
I'm an idiot, after taking the enormous amount of to time replace my heater core, going through the dash board and everything I cannot figure out which hose goes to the upper and lower nipples on the heater core that is currently poking through the firewall. I assume the hose that I left attached to the heater valve should go to the upper nipple. I tried researching this and looking at images, but I cannot find a definitive answer. Your time is very much appreciated.
- 93Regina
- Year and Model: 93:240/940
- Been thanked: 65 times
From the water pump's outlet side, there is a pipe which goes around passenger side of engine block; where it hooks to a hose that hooks to top-side of heater core.Deeseven wrote:heater core
On heater-core's bottom pipe, a short hose goes to heater-control-valve, and then another hose goes to engine block (or head) on driver's side.
- 32 Replies
- 18192 Views
Last post by sleddriver
- 1449 Views
- 1433 Views
- 11 Replies
- 9977 Views
- 5128 Views
