1997 850AWD and P80 moonroof assembly
Has thanked: 2210 times
Been thanked: 1852 times
I have a complete moonroof/sunroof assembly from a 1997 850AWD which is the same as a P80 V/S70 as I was told (I know the parts were interchangeable with a 98 V70XC). It has been removed complete from a car.
Point of this is does anyone want me to post pictures of how it all look out of the car for reference?
Car has been sold it was bought for (wrong leak diagnosis), so I plan to sell it on, but thought this may be of use for others.
Has thanked: 1611 times
Been thanked: 4075 times
I think some pics would be cool for a reference ...can you either post or send?
(Pm for details)
I'll post some photos, and then let me know if there is anything in particular you want more details on.
As promised abscate, I have added below a whole bunch of pictures for everyone's reference.
If you or anyone else wants more detailed pictures of anything, let me know.
Looking from top of unit.
Rear RH corner of tray.
Rear LH side of tray from above
Trying to show front 2 RH roof retaining brackets
LH front 2 retaining brackets
Front of unit with motor unit and mounting points
RH front drain pipe
RH front drain pipe
LH front showing cable and small black drain(?) with clip and front roof mount
LH front drain pipe outlet
Motor and connectors looking from below
Wire connector block looking from front of car
Roof tray looking from below
LH rear drain pipe from below. RH is in identical position opposite
LH front 2 mounting bolts. There is a 3rd at the rear edge.
RH front brackets. Again there is a 3rd at the rear edge.
A couple of notes. Up here in the north I have heard of leaks being attributed to the seal around the glass edge. This is not a 100% seal. The leaks can be caused by the 4 drains being blocked with dirt, and also the outlet drain pipes can crack/split near the outlets from the roof tray.
