Did you know? 🤔
Volvo Alternative flange sealants Permatex Loctite 51813 51817 Volvo 30644517
subzerocarfanatic
Year and Model: 2000 Volvo C70 HT
Has thanked: 9 times
Been thanked: 0
United States of America
subzerocarfanatic
Re: Any Volvo Alternative flange sealants
Post by subzerocarfanatic » Wed Jan 01, 2020 5:26 pm
So can anyone confirm the Permatex 51817 will be fine for sealing the oil pan, I will order the other if i have to but the one horse town I live in only had the Permatex 51817.
JimBee
Has thanked: 13 times
Been thanked: 22 times
JimBee
Post by JimBee » Thu Jan 02, 2020 9:34 pm
I think it was 2013 when I used the Permatex on the pan flange, hasn't leaked. I came very close to getting an admission from a Permatex rep that the Volvo "real thing" is made by Permatex. The person did tell me that the Permatex product is rebranded by several vendors.
Anyway, it's what I used topside (cam cover) and on the pan flange. Use a foam roller and roll it on, not paper thin, but the build doesn't need to be real thick, either. Just make sure the flange is cleaned thoroughly—all the old stuff removed with a utility knife blade held at maybe 10 degree angle. Then wipe it down with 90% isopropyl alcohol. You can also squirt a line of the stuff all the way around, going around the bolt holes, then lightly roll that out to cover the full width of the flange. Working time is practically unlimited since it doesn't set up until it's deprived of O2.
Like I wrote in the other post, make sure you clean the bolt threads thoroughly with a thin wire brush AND get a tap to clean out the threaded holes in the block (including the long vertical bolts and holes at the back end). Then you can ensure even tightening all around, starting from the middle, working across, then out towards the ends. Half tighten first time around, then firm them down. The sealant it designed to fill small gaps if any. On a Volvo pan, the flange is milled perfectly flat, as is the mating surface on the block, so assembling the pieces clean, with clean bolts and bolt holes, you should have a perfect seal.
If you can let the block drain overnight then wipe out any residual oil from around the flange edge of the block, you'll avoid getting any oil on the pan flange when you replace it.
BTW if I remember correctly, the last 2 digits in the Permatex number refer to the size of the container, not the composition of the glue.
These users thanked the author JimBee for the post:
subzerocarfanatic
subzerocarfanatic
Been thanked: 0
subzerocarfanatic
Post by subzerocarfanatic » Thu Jan 02, 2020 9:42 pm
Thanks for such a descriptive explanation,most helpful,thank you! I have a bottle of MG Chemicals electronic Isopropyl alcohol I use for cell phone repairs I used, it's 99.99% Alcohol, expensive stuff but she's worth it I hope one day maybe we can enjoy driving it.Had the C70 3 months almost now only driven 2 times (
subzerocarfanatic
Been thanked: 0
subzerocarfanatic
Post by subzerocarfanatic » Thu Jan 02, 2020 10:06 pm
Here is what I acquired today,only one place had a tube. The image of engine mount is to show the bolt in lower right corner that I can not get to so mount can be removed to make pan installation easier.
ThommyKent
Year and Model: 91 245 97 850 T5
Has thanked: 0
Been thanked: 4 times
Romania
ThommyKent
Post by ThommyKent » Fri Jan 03, 2020 4:06 am
The Volvo anaerobic is made by Loctite.
If you look on the Safety Data Sheet for Loctite 518 it says this:
2. HAZARDS IDENTIFICATION
LOCTITE 518 IND 6ML
2096062 2096062 United States
Anaerobic Adhesive None identified
If you look at the Safety Data Sheet for the Volvo anaerobic it says this:
Anaerobic Gasket Maker 518
495539 37530
United States
Notice the Volvo is described as Anaerobic Gasket Maker 518 meaning it is Loctite 518
They are both manufactured by Henkel AG of Germany
The Permatex will work just fine as it is 518 also, but they do not manufacture the Volvo
These users thanked the author ThommyKent for the post (total 2):
Chuck Wsubzerocarfanatic
Has thanked: 254 times
Been thanked: 809 times
Trinidad & Tobago
Re: Volvo Alternative flange sealants Permatex Loctite 51813 51817 Volvo 30644517
Post by abscate » Fri Jan 03, 2020 7:07 am
Added all part numbers to title for search
Confirmed that the loctite 518xx products are all the same content, the xx denotes package size
Source Loctite Inc data sheet
Pull that harmonic balancer off to access that bolt or use an offset M8 on it
Link To Volvo Glossary
ThommyKent
Has thanked: 0
Romania
ThommyKent
Post by ThommyKent » Fri Jan 03, 2020 10:53 am
Loctite recommends using their Klean n Prime # 37509 as an activator for anaerobic sealants
subzerocarfanatic
Been thanked: 0
subzerocarfanatic
Post by subzerocarfanatic » Fri Jan 03, 2020 2:24 pm
Is this necessary?
Has thanked: 75 times
Been thanked: 237 times
Post by erikv11 » Fri Jan 03, 2020 2:37 pm
No, activator is not required.
'96 855 NA, 145k
'98 V70, T5 tune-injectors-turbo, LPT engine, 285k
'06 S60 R, 160k
ThommyKent
Has thanked: 0
Romania
ThommyKent
Post by ThommyKent » Fri Jan 03, 2020 2:48 pm
Recommendation not mandatory. It does speed up cure time by 50%
