VIDA DICE
2005xc90t
Year and Model: 2005 Volvo xc90
Post by 2005xc90t »
Hey All,
Not sure if I got this in the right part of the forum, but here goes. I just got from ebay (China version) VIDA DICE 2013D. It says it works on Windows 7 PRO which I do have. I have all other requirements.
When I install it, it says VIDA NOT OK and I can't use it. It looks like it's not installing the database because when I go into the log file, it says database not found. Does anyone have any ideas what is wrong? Do I need to find a machine with XP?
Is there anything else needed on Windows 7 to run this software that I don't have?
Thanks! :?:
JDS60R
Been thanked: 3 times
Post by JDS60R »
Most recent VIDA will work on XP pro or Win7 pro 64 bit.
Lots of recent posts on this - Search function is your friend.
Retired
2005xc90t
Post by 2005xc90t »
I've looked all over the net and can't seem to solve the issue I'm having with it. I'm using Windows 7 Pro 64 bit.
Installed as per instructions. Messages reads VIDA NOT OK. When I look at the log, it fails when it seems to be installing the database. Any ideas?
Stravlr
Year and Model: 2004 XC90 T6
Post by Stravlr »
my "guess" - you installed it by clicking on the setup and not opening the cd, reading the "read me" file which would tell you what to do next. remember that it is most likely a "hacked" version and you need some additional steps to make Vida happy.
mf70
Year and Model: V50 2006
Been thanked: 2 times
Post by mf70 »
... or go the VMware route.
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
Are you installing on "C" drive? Vida won't install on any other drive.
Has Net Framework 4.0 installed in the Installed Programs list?
z2003
Year and Model: 2005 V70R
Post by z2003 »
try this:
1. please try make install "as administer"
2. the windows 7 should have no "modify" whatever 32bit or 64bit. I have success on both PC.
3. I meet problem with system permission of OS. so, I reinstall windows 7.
good luck
1996 850 T5
2005 V70R
