i've been on a search to fix a check engine light. I fixed a rotten, disconnected hose on the back of the SAS valve. I was hoping that would solve it, but that didn't fix it. I put a new SAS valve in, and did the VW air pump trick. That didn't do it, either; I have a P0445 code. And there is a slight fuel smell in the cab (not strong enough, I think, to be an actual fuel leak).
I could do the diode trick, but I'd prefer to try to fix it legally.
Ideas on what to try next? Thank you! Rick
1997 850 P0445 code/air pump
- Year and Model: Many Volvos
- Been thanked: 76 times
Is the blower running when you start the car? The SAS really doesn't do much, it heats up the catalytic converter a fuzz faster and that's about it.
- Been thanked: 4068 times
P0455 is an evap code, not SAS.
You probably have bad hoses to the evap canister in the fender well (?)
The J hose is often the culprit and the slight fuel smell is a great tipoff.
Well documented in threads and also in the VOlvo repair database here
MikeHotchkiss
- Year and Model: 2008
Most common cause of an Evap Leak Smell on Volvo S70's is a crack in the "J" hose which is connected the charcoal canister. OTHER causes could be leaks on the Evap Lines and the Purge solenoid(on radiator shroud), but the most common is a cracked J hose which gives off a P0442 OBD2 code.
If a crack is found, replace hose by removing clamps and replace it.
- jreed
- Has thanked: 384 times
- Been thanked: 221 times
On my '97 855, the cause of the P0445 code was a nibbled rubber hose at the rollover valve located next to the fuel filter at the rear passenger's end of the car.
- 11 Replies
- 1987 Views
Last post by Eddystone
- 1829 Views
Last post by bmdubya1198
- 1766 Views
Last post by erikv11
- 3592 Views
Last post by jreed
- 418 Views
Last post by misha
