1999 S80 Brake Fluid Change
sherry007
Year and Model: 1999
Post by sherry007 »
Hi,
I want to change my Brake Fluid since its never changed.
Volv0 s80 1999 2.9 Non Turbo. 183000 KM
Though I do not feel any problem while braking or any other issue but I do wonder it might at least requires a change after so many years.
Please share any link or instructions how to change it as well which brand or type is recommended. Will surly appreciate.
Thanks
matt5112
Year and Model: 1999 S65
Been thanked: 3 times
Post by matt5112 »
The Volvo interval is every two years.
Bleed the brakes till the fluid coming out is clean. Nothing special there.
The only catch is you need a scan tool to activate the abs valves to get all of the old fluid out.
Any DOT 4 fluid is fine. You only need the fancy stuff if you're incredibly hard on the brakes such as mountainous driving or competition use.
jbkeene
Year and Model: 2000, S80, NA
Post by jbkeene »
bleeding is no big deal; you need to get the watery oil out
bleed it once, put in new DOT4, drive a while, and bleed it again to clean out the valves
rmmagow
Year and Model: V70 1998
Been thanked: 2 times
Post by rmmagow »
Can you still buy brake fluid of different colors, say yellow & blue but both are dot4 to help you know when you flushed out all the newish fluid the second time around, before it is actually all discolored?
1998 S70 135K - FOR SALE
2003 GMC Sonoma - 114K - POS
sherry007
Post by sherry007 »
Thanks, can I change fluid one by one, like if I change from front right today....and after few days i will change the Front left one...????
matt5112
Post by matt5112 »
rmmagow wrote:Can you still buy brake fluid of different colors, say yellow & blue but both are dot4 to help you know when you flushed out all the newish fluid the second time around, before it is actually all discolored?
Ate Super Blue has been "outlawed" in the United States.
Here's a link: http://forums.nasioc.com/forums/showthr ... ?t=2540527
sherry007 wrote:Thanks, can I change fluid one by one, like if I change from front right today....and after few days i will change the Front left one...????
It's possible, but there is risk of contamination of the new fluid. It's better to get it all done in one shot.
