I replaced the heater core/o-rings a few years ago after having the smell/film on the windshield. The smell never went away. I decided to fix the A/C last summer and took everything out of the car to clean everything, figuring maybe there was still some residue in there. The heater core itself stinks. Is the smell coming through the plastic? After all, it's porous by nature.
I don't have any leaks. While doing the A/C job, I replaced the evap, drier, condenser and also the firewall assembly where the heater lines pass through. Are these things just junk?
Curious if anyone else has had a similar problem.
Thanks,
Chris
1998 s70 t5 Heater core
cjbmustang
- Has thanked: 1611 times
- Been thanked: 4075 times
The cheap ( but proven ) heater core on eBay is known to stink unless you put in the dishwasher first.
If you do get a leaking heater core, you need to empty the floorboards of coolant too. All the carpeting and soundproofing will smell like coolant unless you wash them out of the car.
cjbmustang
I bought this one from FCP. It only stinks when the heater is on or the heater control knob is turned to a warmer setting.
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
That is when the flapper opens to let air from the core enter the cabin area.
JRL
- Year and Model: Several
- Been thanked: 16 times
Did you read?cjbmustang wrote:I bought this one from FCP. It only stinks when the heater is on or the heater control knob is turned to a warmer setting.
It needed to have been washed first
cjbmustang
I did read it. Did you? I did not purchase this through ebay, like the other member had posted. I believe it was a Behr. Thank you for your contribution.JRL wrote:Did you read?cjbmustang wrote:I bought this one from FCP. It only stinks when the heater is on or the heater control knob is turned to a warmer setting.
What would washing the heater core have to do with anything? Does the hot water/dry cycle seal the end-tanks?
cjbmustang
Correct.rspi wrote:That is when the flapper opens to let air from the core enter the cabin area.
- dosbricks
- Year and Model: '96 855, '98 S70
- Been thanked: 4 times
Chris, apparently the manufacturing oil on the ebay core smells when it gets hot, therefore washing in detergent cleans it off prior to installation. I have not previously heard of Behr cores stinking.
I just ordered one of the ebay ones from Swedish Car Parts. What about taking it to the carwash? and should the Inlet and outlet holes be plugged when laundering this thing? Thanks for any guidance.
Dishwasher or even a few minutes in hot water with lots of suds and a stiff brush will get the oil off. You can plug or rinse the inside with water for a minute when done. It's not rocket surgery.
precopster
- Year and Model: Lots
- Been thanked: 128 times
The autolamps/volvonest heater core smells for about 3 months and so do the cheaper black varieties of heater core. I failed to wash both types and we endured the smell until it evaporated off the external alloy.
- 32 Replies
- 18062 Views
Last post by sleddriver
- 11 Replies
- 9943 Views
- 5117 Views
- 1074 Views
Last post by dorvin
- 14 Replies
- 3633 Views
Last post by precopster
