1999 V70xc What the Heck is Happening with this Car
I am getting different lights lighting up my dash. First the dreaded blinking arrow, then the Check Engine along with the blinking arrow, then the ETS joined them. Then the blinking arrow went off, then the ETS went off and left the Check Engine light the only light on. I am going to get the codes read today, but can anyone tell me what the Heck is Going on With this Car!!!!!!
1999 V70 XC 135K
JRL
- Year and Model: Several
- Been thanked: 16 times
1618 is a communication error code
You may have a short or a wire that's frayed, have fun, it's a nasty code
It also can just be an ABS code needing a new/rebuilt module.
($70 from Matt, you should ask him what to look for first
His email: [email protected].
JRL
Nothing to do with that code
Fogducker
- Year and Model: 850AWD 1997
Might not have anything to do with the code but the dash light problem is similar to a voltage regulator problem so I was just throwing it out there...........? Perhaps you could elaborate on what the problem actually is?
- Been thanked: 4068 times
P0741is a torque converter code...ergo the flashing arrow. I dont know a lot about slush drives so others will need to chime in.
JRL
That would mean the tranny is probably shot but change the fluid on that one.abscate wrote:P0741is a torque converter code...ergo the flashing arrow. I dont know a lot about slush drives so others will need to chime in.
The 4 speeds are tough and it may go away after a fluid change
I can't, you have to start fault tracing wires. As I said check with Matt on this one firstFogducker wrote:Might not have anything to do with the code but the dash light problem is similar to a voltage regulator problem so I was just throwing it out there...........? Perhaps you could elaborate on what the problem actually is?
http://www.check-engine-light.com/trouble-codes
- 3309 Views
Last post by landl4u2
- 946 Views
Last post by Redbox
- 840 Views
Last post by 850TurboTurtle
- 2229 Views
Last post by oragex
- 2862 Views
Last post by jerryv
