1998 S70 Cooling Fan Hard-wire; bypass relay
kickin_it
I have a high mileage s70 I am just trying to keep alive. My cooling fan relay is shot and it looks like the wires were also cut by the fan or some outside force. My question is if there is anyway to hardwire the fan to run only when the motor is on. I do not want to replace the relay, I want to bypass it. I don't mind the noise of the fan but I also do not want to have it running when the car is off for obvious reasons. I just need it to get me to work and back 15 min away. It does not overheat unless the car is run hard for a longer time or stationary for about 10 minutes. Any diagrams or photos of a possible fix would be greatly appreciated. Thanks.
tryingbe
- Year and Model: None
- Has thanked: 1 time
- Been thanked: 26 times
Why not just replace the relay and fix the wiring. It'll be cheaper and easier.
Other wise, you're looking to add wiring, adding relay, finding an ignition on wire, splicing into that wire to new relay and add more wiring...
Why would you want to go thru all that when you can just fix the existing wiring and replace the relay.
85 GLH, 367 whp
00 Insight, 72 mpg
00 Insight, 72 mpg
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
+1
Fixing it correctly will not only be easier,
it'll save any future owner the trouble of
figuring out the hack and making it right.
- Year and Model: Many Volvos
- Been thanked: 76 times
The problem is that you really can't just tap a slot in the fuse box for the engine cooling fan and expect for it to work for very long. The fan relay supply has a fusible link, directly tied to the battery, that is rated for 60 Amps. The B+ line on these cars is pretty weak to begin with and taking on that much more current draw to the fuse box might significantly hasten the car's ultimate demise.
It would be easy enough to use either the yellow or the yellow/white wire to trigger a relay (the triggering is done by those wires going to -) and then tie the relay output to either the red or the green wire on the fan. It all depends on what speed you want the fan to run at.
- BEJinFbk
We're talking about a 60 amp relay here.
These aren't just laying around like a 30 amp
bosch SPDT 5 pin. Might as well just fix it.
Bad relay? Hit the junk yard. It doesn't have
to be expensive to fix it "right". And at the
end of the day, it WILL be easier.
tryingbe
If you want to put more work into it and do it the way you want, by all means, do it.kickin_it wrote:Not really what I asked for but thanks for the opinions anyways.
I've added Volvo fan to my Dodge Daytona, Dodge GLH, Shelby CSX, and a Volvo 240. You would think my opinion would count heavily.
Daytona install
CSX install
GLH install, custom shroud
85 GLH, 367 whp
00 Insight, 72 mpg
00 Insight, 72 mpg
- phils94850
- Year and Model: 2009 s60 turbo
turbo dodge.. ive had a few of those...
1996 Platinum Edition
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
IF you have a pick n pull type JY near you the relay will be cheap and you can cut the harness to get some wires for repair. The wires that failed I would assume are the two small gauge relay trigger wires. Those can be installed back onto relay even when the plastic molded stuff fails and the wires no longer stayed put in the connector.
The cooling fan relay is the same for 850, 92 and later 940/740/960/s90/v90 so the models you could pluck one from is pretty wide.
You will not find a switch that will handle the fan load for cheap so you would likely spend more money rigging around the std setup than you will at a pick n pull.
richardgengle
- Year and Model: 2004 v70
could i connect the fan's purple wire to battery hot or ground ... or maybe to the alternator [thinking it would only have voltage when engine is turning?]
i ask this because the fan only seems to work if i reverse polarity to the 2 big wires.
- 1739 Views
Last post by Ozark Lee
- 734 Views
Last post by tryingbe
- 22 Replies
- 3061 Views
Last post by jonesg
- 762 Views
Last post by Rcooper
- 275 Views
Last post by PatternFlyer
