is there anything odd or different when replacing the cv joint/axle on this car?
my freind is a mechanic but i'm making sure he won't run into something weird bcuz i dont need to be stranded if it needs special "volvo" tool for i am too far from a autostore or towing.
is there an instructional video?
2000 s70 pass. cv axle question before i start
- Year and Model: Many Volvos
- Been thanked: 76 times
The right hand (passenger's) side is real easy and it requires no special tools. The axle is held in place by a cap over the carrier bearing and once the hub side is off the axle just slides out after the carrier bearing cap is removed.
On a FWD I usually just remove the control arm bolts at the subframe in order to swing the steering knuckle free since I can't ever manage to get the ball joint loose without tearing up the boot. You should use new nuts and bolts for the control arms.
- 20 Replies
- 3806 Views
Last post by oragex
- 1236 Views
Last post by dux02v70
- 490 Views
- 15 Replies
- 36887 Views
Last post by Krons
- 615 Views
Last post by Blacklab467
