2007 S60 Wipers have a mind of their own
MadogV
- Year and Model: S60 2.5T 2007
Just purchased a 2007 S60 2.5T and I have noticed that if you turn the wipers on they will not shut off. They will run at different intervals and stop at different places on the windshield. The only thing that I have found to work is turning off the car for a long period of time when the blades are at the lowest position. The wiper lever on the column does absolutely nothing once they have been turned on.
JRL
- Year and Model: Several
- Been thanked: 16 times
Sounds like the rain sensor button is somehow stuck in the on position, you may need a new stalk
draser
- Year and Model: 2005 S60 2.5T
- Been thanked: 2 times
Sounds like bad wiper motor.. Switches in the cam mechanism stuck closed.. Hence stopping wherever on the glass. I'd get the wiring diagram, remove motor and test to confirm.
2005 Volvo S60 2.5T, Zimmerman/Akebono brakes
2012 Honda Accord, EBC slotted rotors
DGM
- Year and Model: V70 2.4i 2005
- Been thanked: 3 times
I would have a look at the wiper arms linkage first. Generally the linkage arm pivots need to be cleaned and lubricated. Most likely the mechanism is partially stuck and it resists against motor operation.
V70 2005 2.4i 195,000km, sold
S70 1998 T5 355,000km, sold
960 1994 80,000km, sold
760 1990 Turbo 265,000km, sold
JRL
Yes, take it to get the stored codes read, (Volvo dealer or someone with a VIDA DICE set up)
