I performed a manual transmission oil change replacing the 16 year old oil with Mobil one synthetic
Key word M56 manual transmission oil
1999 V70T5M56 manual transmission drain DIY , Mobil 1 SYN oil review
- Been thanked: 4063 times
- regent
- Has thanked: 2 times
- Been thanked: 12 times
What about an angled box wrench on the plug, and then have your three cats teach that puppy who's bossabscate wrote:...Can't get socket on this puppy...
BTW, what did your old oil look like (besides sediment, did you see any brass particles from the synchros)
When I was draining my 5 sp manual (the 1987 340DL) I was surprised to see how clean everything was
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired
1987 340 DL - retired
2015 BMW 335i
I actually promise I will strain it through a coffee filter to see how much metal it has, after 4 drivers and two teenage learners on the transmission. I could not see any.
An angled 24 mm box fit the drain perfectly. An open crescent wrench on that big plug would be fine too.
- regent
Since the car is a teenager (1999), have you had the fun to do the clutch yet?
I had to replace the disc on mine (it started slipping only because of a leaking RMS at under 75k and 10 years in service). I recall the plate and release bearing still looked like new ...
2015 BMW 335i
2015 BMW 335i
Original clutch with 5 drivers and three learners. Still great clutch action, although, of course, they die dramatic deaths. I actually launched and retrieved a 3000 pound boat with this car once.
- Year and Model: Many Volvos
- Been thanked: 76 times
Jimmy made a great suggestion about changing lube in the transmission. Remove the fill plug first! If for some reason it is stuck you haven't drained the transmission and then have no way to fill it back up.
I'm guessing that one came from experience.
Well, you can pop the driveshaft and fill it through the driveshaft hole...see picture
- regent
Or, you could rig up a sealed connector to the DRAIN and fill it that way - either gravitationally or using a $9 Fluid X-fer Hand Pump from HFT
2015 BMW 335i
2015 BMW 335i
Or drill into the Al case and then bung it up with a rubber stopper....is that too "ghetto"
That is, more or less, the official procedure to add the drain to the bevel gear except that you drill through a bolt hole. The factory procedure does specify to use thread tape when the stud goes back in though which I guess de-ghettos it.abscate wrote:Or drill into the Al case and then bung it up with a rubber stopper....is that too "ghetto"
- 11 Replies
- 11678 Views
Last post by STSCowboy
- 11 Replies
- 2020 Views
Last post by Eddystone
- 1887 Views
Last post by erikv11
- 5376 Views
- 1261 Views
Last post by FL850_1997
