I ordered a timing belt replacement kit, and it included the automatic tensioner, but mine is fitted from factory with the piston type tensioner. Are these interchangeable if I remove the piston? Or do I have to re-order the piston and pulley assembly for my specific car. It's been really hard to figure out what parts go on my car, as it seems after a certain vin number Volvo changed some things, and all the parts stores don't interchange properly.
also, is it recommended to replace the piston tensioner or just he pulley system is pushes against?
Car has 140k last replaced at 70k
Thanks.
1998 xcv70 timing belt tensioner interchangeable?
- Year and Model: Many Volvos
- Been thanked: 76 times
You have the wrong kit. If your car has the hydraulic tensioner then that is what you should replace it with.
The hydraulic tensioner and the tensioner roller should both be changed.
- 1220 Views
Last post by cn90
- 1218 Views
Last post by jblackburn
- 10621 Views
Last post by vtl
- 2295 Views
- 815 Views
Last post by DatSpool
