Hey fellas...
I bought a 2007 S40 2.4i with a bad motor. My mechanic is certified and has Volvo experience so this isn't shade tree. Replacement motor went in fine, they put it back together and everything was swell. Started right up, runs like a Swiss watch. They drove the car into the bay to begin with, so we know the trans worked fine. They never separated the torque converter from the trans during the install, so we know it is seated all the way on the input spline. Here's the problem...the car will not move. It engages, you can see that the spline is reading RPMS at the speed sensor but the car will not move. When you shift it into gear there is no RPM drop...it never comes under load. The trans worked fine beforehand. Did my mechanic miss something here?
2007 S40 URGENT! Did engine swap...trans worked fine before,
Craigd2599
- Year and Model: 2007 S40.
- Has thanked: 3 times
Craig D
Philly Boy in Lynchburg VA
2007 S40 Previously: 2 850's and an S80
Waiting for that "R" model barn find
- 1778 Views
Last post by Samzebian
- 1909 Views
Last post by volvolugnut
- 4225 Views
Last post by Legofan
- 1793 Views
Last post by rspi
- 801 Views
Last post by Clemens
