Hello
There is a group of wires (4 in total)
The green goes to the overdrive, and is connected to the solenoid.
The blue turns into a red after a rubber connector.
Two with rubber ends sit halfway down the gearbox and are missing their insulation.
Could someone identify these please.
Kind Regards
Thanks MVS
1986 745t 5spd Wires dangling under body beside gear shifter
h20ham
- Year and Model: 1998 xc
Hello
I can t tell ig it is blue or green. Light in colour
Thanks
Thanks
68 125 b18 4 speed
72 164e b30 5 speed
79 242 16v 5 speed
84 744 T 5 speed
86 745 T 5 speed
88 765 T aw71
91 745 T 5 speed
95 965 T shift controller in progress
05 xc90 rough idle
72 164e b30 5 speed
79 242 16v 5 speed
84 744 T 5 speed
86 745 T 5 speed
88 765 T aw71
91 745 T 5 speed
05 xc90 rough idle
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
The OD uses a 4th gear switch so that OD only works in 4th. There are two switches on top cover. One for reverse lights and the other the 4th gear sw.
Does the OD work?
Do the reverse lights work?
Does the OD work?
h20ham
Humm, Thought the reverse lights worked. But then again!
I had thought the reverse lights were activated by the gear selector in the car, not externally on the transmission.
The two open banana type plugs have lost all the insulation and are exposed. Where should these go to or come from.
I would suspect the reverse light connection on the transmission is on the drivers LHD side. Correct?
Thanks
Thanks
68 125 b18 4 speed
72 164e b30 5 speed
79 242 16v 5 speed
84 744 T 5 speed
86 745 T 5 speed
88 765 T aw71
91 745 T 5 speed
05 xc90 rough idle
72 164e b30 5 speed
79 242 16v 5 speed
84 744 T 5 speed
86 745 T 5 speed
88 765 T aw71
91 745 T 5 speed
05 xc90 rough idle
- 718 Views
Last post by cn90
- 823 Views
Last post by Falcor
- 21 Replies
- 2158 Views
Last post by Fosgate
- 726 Views
Last post by Blockpartie
- 1202 Views
Last post by Ozark Lee
