99 C70 - bucking around 3k when hard accellerate
when i am going heavy on the gas pedal my car bucks hard like it lost all power then in a second catches it and puts you back in your seat. this will occur through 1 to 4 gear when only accellerating hard and only happen around 3 to 4 thousand RPM. would could be my problem? i can not seem to figure it out. I have the 2.3L T5HPT 5spd manual.
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Wondering if it's overboosting and cutting power.
How are your vacuum lines at the turbo and turbo control valve on the airbox?
When's the last time you changed spark plugs? I saw blow-out at 5K on a set of old spark plugs - power delivery and upshifts were very rough.
'98 S70 T5
2016 Chevy Cruze Premier
Vacuum is all good, turbo has some oil leakage, spark plugs only about 15k old double plat. If I disconnect the battery for some time it won't do it for at least a few hundred miles. I will check the spark plugs tonight though
jblackburn
Might be your problem.spark plugs only about 15k old double plat.
These cars HATE platinum plugs aside from the Volvo OEM ones - I actually tried some double platinums and my car did what I said earlier at 5000 RPM after only 10,000 miles on the plugs. Stick to iridium or copper plugs in boosted cars.
'98 S70 T5
jblackburn
Bosch 7955 FR7DC or NGK BKR6E ("copper")/EIX (iridium). The copper versions will last ~30,000 miles or so.HulkC70 wrote:I will do that right away. Thank you. Any suggestions on the best plug brand to go with on this?
Or you could always pick up a set of Volvo OEM plugs.
'98 S70 T5
- 2365 Views
Last post by carboncow
- 3343 Views
Last post by oragex
- 3230 Views
Last post by P2Apprentice
- 3607 Views
Last post by erikv11
- 1056 Views
Last post by PS78
