2002 S60 fuel pump relay location...not same as 2003...
Lowmiles
Year and Model: 2002 S60
Post by Lowmiles »
I saw a post with the location of a 2003 as being CMI12 in the cabin fuse box. Mine is totally different, having just fuses, no relays at all.
where is it on a 2002 s60 2.4 non turbo?
thanks, I'm working on getting a manual soon...
jimmy57
Has thanked: 5 times
Been thanked: 322 times
Post by jimmy57 »
Are you sure you aren't disregarding the 1/2 width relays as being relays?
Lowmiles
Post by Lowmiles »
Hi jimmy.
I mean there aren't any relays of any size in the cabin, unless they are behind the board with the fuses or something...
jimmy57
Post by jimmy57 »
The "normal" size relays are used for some things on that car but the fuel pump relay is 5/8" wide x 1 1/4" long and about 1 1/4" tall. it is on the upper left on the CEM under left side of dash.
Lowmiles
Post by Lowmiles »
thanks for your responses jimmy.
again for whatever reason my CEM only has fuses, no boxy relays...on left side in that pocket between door and dash where fuses are.
