Back in may i did lots of work on the front end. I put in Sachs shocks and all new gear around them with the exception of the coil springs. I noticed today there is a small gap 1/8" underneath the strut mount caps. I am thinking the coil springs are weak?? Not sure what to do with this at the moment. Greatly appreciate any thoughts on it.
98 S70 There is a gap under the front strut mount caps
- Has thanked: 311 times
- Been thanked: 817 times
There should be a gap, that is totally normal. Bounce on the front of car you will see the gap open and close.
kevins s70
- Year and Model: 2007 XC70
Thanks for the response. I did try bouncing the front and didn't see any change - maybe i didn't do it hard enough. I just saw the gap and thought it shouldn't be there. I will call this closed - thanks again.
JRL
- Year and Model: Several
- Been thanked: 16 times
Normal position
- 14 Replies
- 7187 Views
Last post by erikv11
- 888 Views
Last post by GreenMagicMan
- 1803 Views
Last post by shiloh51933
- 2536 Views
Last post by mecheng
- 2293 Views
Last post by Jeney
