Gang -
My driver side low beam was out. When I went to change it I noticed the small black plastic piece holding the 2 female connectors (which attach to the bulb) had partially disintegrated. I connected one of the female leads directly to the bulb without the plastic piece but left the other one attached to the plastic since that one was still being held firmly. I read somewhere that the little plastic holder could be bought separately. Has anyone here been able to replace that plastic piece (while using the existing wires and female connectors?)
BTW, the bulb was fine and reconnecting everything solved the problem - for now at least.
I do notice more Volvos with burned out headlamps than other makes.
Thanks.
Bob
2004 V70 Headlight Connector (low beam)
- Been thanked: 4063 times
After wrestling four hours with an H11 headlight change on my 2005, just reading this thread title put me back into therapy......
nickbw898
- Year and Model: xc702002
- Has thanked: 1 time
- Been thanked: 5 times
A far better solution is to buy the short adapter with ceramic bulb connection. Your existing connectors attach to the male fitting in the opposite end to the bulb fitting. and you can cover them with insulating tape if you are ultra cautious like me. The whole thing coils nicely within the weather sealing cap that backs the headlight access. these work equally well with the H11 and H7 bulbs.
- Been thanked: 504 times
Hi guys,
What is the consensus here?
- Volvo OEM 8678122:
https://www.fcpeuro.com/products/volvo- ... or-8678122
Or...
- Generic H7 Bulb Ceramic Insulator?
https://www.amazon.com/TOMALL-Connector ... B07FQLB52C
Or...
Has anyone used this Genuine Volvo connector PN 8678122?
One post from S80 here:
https://volvoforums.com/forum/volvo-s80 ... lem-50761/
93SCMax
- Year and Model: 2001 V70 T5 mt
- Has thanked: 36 times
- Been thanked: 45 times
This is what I used when mine disintegrated.
https://www.ipdusa.com/products/9129/12 ... osser-7444
Since the original Volvo part didn't hold up, I opted for another brand, plus the wires are already attached to this one. Just splice or solder in and tape.
