2005 v70 ticking
My 2005 Volvo v70 is ticking with 135k. Coming from the top end. It's shooting a code, P0014(Exhaust Camshaft Position Timing-Over-Advanced Bank 1). I just bought this car on a good deal. Any help will be great.
DrJammer
- Year and Model: 2000 V70XC - 195k
- Has thanked: 1 time
Without much knowledge, it may be a faulty CVVT solenoid at that mileage. On the passenger side under the spark/wire cover near the belts.
Could be an easy fix of replacing the solenoid (make sure it's exhaust). Get a new gasket too.
Or you can try to take it off and clean it out. I did this repair on an earlier model (pre 01) and decided to buy used OEM due to harness connection had changed. I figured I could try that 3x before it would add up to the cost of a brand OEM.
I would do plenty of reading though as it could be an all timing issue? here are some links
https://www.matthewsvolvosite.com/forums ... 14#p194177
https://www.matthewsvolvosite.com/forums ... 14#p271317
Hopefully someone with better knowledge on the P2s will chime in.
Ex-Volvos
2004 v70 N/A - traded in at 75k
2008 S60 - leased
1998 S70 T5 - might still have her if I knew about this forum when I owned it
2008 S60 - leased
- Has thanked: 2854 times
- Been thanked: 1332 times
Oil level good? These inline fives tick at the top when oil's low.
rubbersidedown
- Year and Model: V70 2001
Sounds like a cam position issue. The ticking can perhaps be unrelated.
Make sure you have oil pressure at idling, in case the ticking goes away when revving the engine.
Make sure you have good oil filter with not too much pressure loss (e.g. Volvo OEM)
Make sure you have good oil thickness (not full synthetic, and perhaps 10W40 if you do not live in snow country)
Lifters (they are hydraulic) can be worn and leaky/stuck creating more lift clearance than normal.
Oil pump can also start to leak - loosing pressure.
hermechanic
- Year and Model: 2- '02 V70 T5 M/Ts
It's my understanding that the CVVT solenoid controls oil pressure acting on a spring to change the valve timing. If upper end oil pressure is insufficient, ticking can occur and proper valve timing cannot. Hence the fault code.
- 23 Replies
- 3828 Views
Last post by Blacklab467
- 909 Views
Last post by GBS
- 1142 Views
Last post by sleddriver
- 1665 Views
Last post by polskamafia mjl
- 404 Views
