Brake dust...
Bearly Bear
Year and Model: S80 2000
Post by Bearly Bear »
I was looking at my new (used) S80 and notice quite a brake dust coloring on my Front tires. I read/heard that the Rears wear faster...
Any ideas ?
Thanx
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
With the correct matching pad compounds on front and rear axles the fronts will ALWAYS wear first as they handle 60-80% of the braking force.
Pads can last 4 or 5 times longer on the rear axle with gentle driving.
Juan62
Year and Model: S70 T-5M 1998
Been thanked: 2 times
Post by Juan62 »
When you decide to change the pads, you may want to look at Akebono pads; Rear(# EUR795) and Front (# EUR794).
NOTE: These brake pads are Ceramic. The main benefit of using a ceramic pad is that it produces less brake dust compared to a semi-metallic pad without sacrificing braking power.
98 S70 T5-M Brick for life
