2001 C70 Water in convertible top storage hatch area
cuhfs
- Year and Model: 850,XC70,XC90,S60,80
- Has thanked: 17 times
- Been thanked: 31 times
Attention anyone with a convertible... The area where the top goes down into is gathering water when it rains. I found 4 hockey puck sized drains. The rear two drains I was able to remove their covers and I used a shop vac to clear the drain hose so water does not sit. Drains cleared! There are 2 more drains that are forward and under the top mechanism and are nearly impossible to get at to remove the cover and hence can't vacuum out. Please advise any tips for clearing the front-most convertible hatch drains. Thanks
04 C70 Convert Auto
06 XC90 Auto (ORE) #401/800
06 S80
05 S80
12 S60
04 XC70 Auto (Parts car)
96 850 Wagon Manual Trans & 98 V70 (gone)
95 850 Sedan Auto Trans (gone)
04 XC70 Auto (gone)
04 C70 Convert (gone)
01 C70 Convert Manual Trans (gone)
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
cuhfs
Anyone??
04 C70 Convert Auto
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
I don't have a C70 (yet) but can you find the bottom of the drains from underneath in order to clean them out? Use an air hose and put a towel at the drain to catch whatever comes out. The sunroof drains on my XC90 have a problem in pollen season, just like I do, that's how I clear them. Or can you run the top partially up or down, and stop it at an intermediate position ( ignition key off) and access them?
Current Volvos:
- FLXC90
Another though...is there a manual release for the top I order to SAFELY position the top in order to access the forward drains?
Current Volvos:
cuhfs
Thanks. the tops is being stopped mid point for access. I will jack it up the weekend and look from below.
04 C70 Convert Auto
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
- 3364 Views
Last post by cuhfs
- 1151 Views
Last post by kahl
- 9844 Views
Last post by jimmy57
- 377 Views
Last post by goldmandan
- 963 Views
Last post by PimPam369
