Recently I started using my 960 even though it needs a replacement rear main seal.
I live in regional Western Australia and many months ago while working in the city I noticed my fuel economy was a tad poor, twice I had the check engine light come when the fuel was low.
When I checked the codes what popped up was front o2 sensor, I cleared the codes and the same code has not returned, however the fuel economy has plummeted eg.worse than 13mpg. Also tail pipe is very black.
I also notice slight miss at idle and sometimes I can feel it in normal driving.
My question is can the O2 sensor be faulty and not throw up codes, I guess a faulty O2 sensor could affect economy.
Or what other sensor can be faulty that doesn't throw code and can affect economy and is there a way of testing sensors.
Cheers
in advance.
1993 960 Really poor fuel economy
- 93Regina
- Year and Model: 93:240/940
- Been thanked: 65 times
Yes...with two O2 sensors, there will be a code on newer vehicles.Kappy5003 wrote:My question is can the O2 sensor be faulty and not throw up codes
When parts like spark plugs, wires, O2 sensor, etc., have not been replaced in a long time, replace them.
Fuel Injectors - Around here, it cost from $10.00 to $15.00 (US) (each) to have injectors inspected/clean; with older vehicles, they should be pulled and tested.
Compression Test - If all cylinders are similar, then your issues are related to above, most likely.
Kappy5003
- Year and Model: 1994 960
Thanks,
My 960 has a OBD1 system, is it possible to have had a O2 sensor code that was cleared and still have a faulty O2 sensor even though I now get no code?
Injectors were only done about 40 K ago.
Cheers
Cheers
precopster
- Year and Model: Lots
- Been thanked: 128 times
No need for spark plug wires on these are they're a coil on plug setup.
Anything is possible however from my experience owning a 1993 960 the fuel pump under the passenger seat can begin to fail thereby dropping fuel pressures and forcing you to floor the pedal to add more fuel causing high fuel consumption due to poor atomisation at the injectors.
Check fuel pressure before replacing any other parts.
- 93Regina
O2 sensors can last upto 100,000 miles (US) if no containment(s) act on them. Anti-Freeze, some chemical additives, oil, leaded fuel, etc will destroy an O2 sensor.Kappy5003 wrote:O2 sensor code
Kappy5003 has a good suggestion, check rail pressure; of course, if fuel filter has not been changed in past year or two, then change it outl
Remove it, and examine it.
Kappy5003
Thanks Mike
Oops don't know how I got this wrong, mine is actually an Oct 94 build.
Couldn't find fuel pump under passenger seat doesn't even seem enough room for one.
Doesn't seems as if extra pedal is needed.
What do I need to test fuel pressure,can I do it my self ? I live about 250 km from anyone that cares about volvo's.
So having had a look at some testing of O2 sensors an O2 fault code may not be a faulty sensor only a reaction by the sensor yes??
- 93Regina
A cold engine, and maybe a tire pressure gauge might work for a quick/dirty check. Use cloth to shield spray.Kappy5003 wrote:What do I need to test fuel pressure
Volvo 960 basic testing
Volvo Maintenance FAQ for 7xx/9xx/90 Cars
Something like this might work: Actron CP7818 Fuel Pressure Tester Kit
On 240/940 engines, a Ford pressure tester should work.
Ford 90' Fuel Inj Adapter
When was last time timing belt was changed?
2.9L 6-CYL 1994 Volvo 960
If your tailpipe has a blackish carbon look, so does your O2 sensor...O2 sensor
Check your rail pressure, pull the O2 sensor....
Kappy5003
Timing belt done about 40k kilometres ago,idlers,tensioners everything.
I see a valve nipple at the firewall end of the fuel rail is that where I test fuel rain pressure??
- 93Regina
I assume so, unscrew and test when cold; if a tyre gauge works, throw it away when done.Kappy5003 wrote:I see a valve nipple at the firewall end of the fuel rail
One would prime the system; on 240/940 of that vintage, you just turn the key to on position, and fuel pump(s) should prime the fuel rail.
As noted, a Ford pressure tester might work.
- 2172 Views
Last post by Chock
- 2238 Views
Last post by RickHaleParker
- 1152 Views
Last post by Krons
- 2311 Views
Last post by mydamnvolvo
- 933 Views
Last post by RaulGuichard
