Idle is jumping. Never dies but will continue to bounce from 500 to 1200 rpm when in neutral. I have the 99 volvo c70 2.3L htp5 speed manual transmission.
I have before unplugged the MAS and opened a vacuum line and it no longer bounced but it high speeds throttle would get shakey. If I unplug just the MAS it will bog out but I can re start then it I'll position for a minute but then bounce again.
Thank you for further advice
99 volvo c70 2.3l turbo idle problem
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Codes? Could be a vacuum leak, MAF or ETM.
- rspi
Contact rspi..
What brand MAF did you use?
- 19 Replies
- 7471 Views
- 18 Replies
- 1560 Views
Last post by bmdubya1198
- 15 Replies
- 7864 Views
Last post by tango_1000
- 613 Views
Last post by phils94850
- 1488 Views
Last post by jimmy57
