96 850 Are cams "trapped"?
JimBee
- Has thanked: 33 times
- Been thanked: 43 times
If piston #1 is not slightly before TDC when the cams are properly aligned and installed, can they get trapped so that it's impossible to time the engine without pulling the cams, setting the #1 and starting over?
jimmy57
- Been thanked: 322 times
I have had cams that I needed to move in order to get timed properly that would bind. I didn't remove cams to remedy this. I turned the crank a little and then turned the cam and then turned the crank back a few degrees and then the cam would turn until it was back around where it needed to be.
I've studied the piston locations with crank at assembly index head off and if you turn the crank to drop the highest piston another piston will come up enough to be in the way of full valve lift.
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Not sure what you are asking, however, if the crank is on it's mark, you can spin the cams around 360 degrees on the I5 motor. It may be possible to walk the cams around enough to get the crank on mark. Once the crank is on mark, the cams can be spun around anywhere.
- 556 Views
Last post by JimBee
- 437 Views
Last post by Brucebo
- 1110 Views
Last post by dynamaniac
- 1250 Views
Last post by chrism
- 20 Replies
- 5468 Views
Last post by dikidera
