2001 Volvo v70 Cooling Fan kill my battery, doors won't open
Volvonoob84
- Year and Model: 2001
damn my cooling fan kill my battery. My doors won't open with the remote control. My keylock left front door not working. I can't find any soulition about open tailgate manualer with key. I need to charge, but can't reach the battery in boot. Anyone here have a solution?
precopster
- Year and Model: Lots
- Been thanked: 128 times
It's a wagon. Climb over the seats or fold them first to make a flat floor then you have all the access to the battery you need.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
A used cooling fan is under $100 off Ebay, takes about 20 minutes to replaceVolvonoob84 wrote:My keylock left front door not working.
I think it looks like this (not sure if the same exact model)
http://www.ebay.com/itm/00-99-98-volvo- ... 71&vxp=mtr
The door lock is seized because never used, use a little bit of Liquid Wrench on outside around the barrel and a little bit inside (really, no need to soak it), then start trying to turn a little bit the key without forcing (or if the key doesn't even go inside the lock, start by pushing gently the key inside over and over again). Keep trying gently, it should work again in less than 10 minutes.
precopster
That cooling fan won't suit a P2.
Forgot to mention that In the engine bay is a jump strart point. Connect another car or another battery or a charger to boost your electrical system to allow locks to work.
- 548 Views
Last post by Volvonoob84
- 2421 Views
Last post by SuperHerman
- 796 Views
- 4473 Views
Last post by ajwsurfer
- 451 Views
Last post by wisewoman
