'06 S60R Caliper Bleeder Valve Replacement
vjaneczko
- Year and Model: 2006 S60R
- Been thanked: 7 times
Thought I would replace the brake fluid since it looks more like maple syrup than DOT4. When I went to close a bleeder valve, it got rounded - in the open position! I figure I might as well replace all eight of them but they seem rather expensive if I go with Volvo parts - about 15 bucks a piece. A lot of interweb posts suggest I can save a ton of cash if I go generic but no one that I have found indicates the size/thread count for these things. Can anyone help?
1997 855 GLT - R.I.P.
2006 S60R - For ME!
2006 S60R - For ME!
chrism
- Year and Model: S80 / 2005
- Has thanked: 7 times
- Been thanked: 89 times
If you take one of the old ones to the auto parts store you should be able to match it up to a new one.
If any of the old ones are not rounded and the threads aren't rusted beyond hope, I'd clean them up and re-use them. They're probably better quality than any generics you'll find.
vjaneczko
... and there's the rub; if I take one out, I won't be able to stop at the parts store
2006 S60R - For ME!
2006 S60R - For ME!
jimmy57
- Been thanked: 322 times
If you remove a bleeder screw and don't want all the brake fluid draining while it is out all you need do i depress brake pedal 1 inch or more and hold it there with a stick or other item wedged between pedal and front of seat.
chrism
"... and there's the rub; if I take one out, I won't be able to stop at the parts store..."
Were you planning to drive it to the parts house with one bleeder stuck open?
vjaneczko
Yes, because I am a moron.chrism wrote:Were you planning to drive it to the parts house with one bleeder stuck open?
I was able to close the valve with a socket. Just looking for the specifications of the thing.
2006 S60R - For ME!
2006 S60R - For ME!
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
If I remember well, not much luck to find a replacing part other than the one from the dealer or, better idea, look over Ebay, maybe some breaker sells the nipple individually.
- 13 Replies
- 2348 Views
Last post by JRev
- 1079 Views
Last post by oragex
- 3464 Views
Last post by ryanmcgrim
- 15 Replies
- 6410 Views
Last post by wizechatmgr
- 841 Views
Last post by Iceman12596
