Hi, my car was making a growling like noise at startup for last few weeks...but the noise only lasted about 10-20 seconds.
Pulled out of driveway the other day, and within 1 minute loud noise from AC compressor started...popped the hood and saw smoke coming from AC clutch....
Prior to all this, the ac has blown very cold, so I'm pretty sure no leak in ac.
Does anyone have the VADIS write up for removing the AC clutch or any experience? I would like to remove the clutch, check the compressor & if the compressor turns smoothly & freely, try to just replace the clutch.
I am concerned if I need special tools like clutch removal tool, & 2/3 jaw puller....
Thanks very much!!
05 S80 AC Compressor Clutch Repl
Bruce Nussman
- Year and Model: S80, 2001
Most parts houses like Auto Zone loans special tools. Try You Tube web site, and type in changing A/C clutch on your year and model, and will probably
have a video.
Good luck!
Bruce
have a video.
Good luck!
Bruce
I have a 2005 S40 T5. I just changed the a/c clutch on it. found a new one on E-Bay for about $65.00 new. Needed an a/c clutch pulling set, I got one from Harbor Freight for cheap for a different car last year, I don't see the same set. I had to make a pin from a long (2") driver bit to put into the bolt hole to get the center piece out. Used a gear puller to get he outside pulley off. Had to unbolt the compressor to get the old wire out and the new one in proper place, but did not have to disconnect the a/c lines and did not open up the system. Removed pass. front wheel, took out fender wall, pretty much had full access. I was slow, wasn't sure what I was looking at, had it apart and back together in a few hours. I could probably do it again in about an hour. Center needed to be shimmed properly. Spec is I think .040"-.060" gap between center hub and pulley. I looked at a bunch of information all over before I started, not sure where I got that. Anyone else, feel free to correct me.
- 1218 Views
Last post by Chassis
- 597 Views
Last post by vtl
- 891 Views
- 469 Views
Last post by Ozark Lee
- 680 Views
Last post by Daniel-isley
