2000 S80 T6 Transmission shims
MyS40T4
Year and Model: S80 T6 2000
Post by MyS40T4 »
While rebuilding the transmission, I've found that both the final drive and transaxle clearances are out of spec.
While a .010" transaxle shim is available from TripleEdge, the postage cost is significant at $30-40 (to Australia). The .020" final drive shim required are significantly larger diameter for the Volvo over the GM transmissions and are not available.
I've looked at having some laser cut shims made locally and have been quoted A$90 (their minimum order) which would give me 6 of each size spare.
This is a long shot, but is there anyone who knows of a more cost effective way to make these shims and could post them to Australia? If not I'll get them made locally and be able to supply for transmission rebuilds :-)
Listens for cicada noises, a tumbleweed rolls past... :-)
