Hey All,
Just recently replace the starter but now I'm getting code 154 from A6. The idle is rough but it smooths out once you start driving. The big problem is now she will suddenly stall out without warning. She'll start right back up. Could the clogged EGR causing the poor idle cause this or should I be looking for something else. I've listened for the fuel pump and thats working, battery and alternator check out ok. I'm at a loss as to what it could be. Thanks in advance !!
93 850 Pulled code 154 from A6
- phils94850
- Year and Model: 2009 s60 turbo
Did you check for a vacuum leak ? Was it doing this before you replaced the starter ? Make sure all you electrical connections are correct.
1996 Platinum Edition
