1995 850 Instrument Cluster Failure
polskamafia mjl
Has thanked: 19 times
Been thanked: 21 times
Post by polskamafia mjl »
Good evening MVS,
Ever since I've owned this car ('95 T-5R) the coolant temp gauge, fuel gauge, and tach have intermittently not worked. I tried to fix this by swapping in a different cluster only to find that it was from a wrong year 850; the speedo didn't work, the transmission arrow was flashing and the ABS light was on.
I found this thread: https://www.matthewsvolvosite.com/forums ... =1&t=42486
where OP took the cluster apart and re-soldered the connections on the board.
Anyone have any experience doing this? I took mine apart and managed to find one connection that is obviously bad. It is on the fuel gauge/temp gauge side and presumably could be why those two gauges don't work. I've been searching the tachometer side of the board but I don't see any bad joint there. Any ideas on how to effectively check these joints?
Broken connection on fuel/temp gauge side of board.
jreed
Has thanked: 384 times
Been thanked: 221 times
Post by jreed »
I looked over your images and didn't see any other obvious signs of misplaced or damaged joints. I noted the multiple moose images patterned in the top metal layer on the circuit board -- cool & fascinating!
polskamafia mjl
It is difficult to see the joints well in these pictures. More resolution would be helpful. I suppose I'll try fixing the broken joint I found and hope it fixes my problem. I won't hold my breath, though.
Yes, the Moose herd on the PC board is pretty cool. A nice little Volvo easter egg.
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
These VDO clusters are failing. My system had a bad wire harness at the top of the cluster so I wired in a harness from another junked car. You can test the cluster by opening the hood, jumping A7 and pressing the button 3 times. The temp gauge should go to the bottom of the red mark, the speedo and tack should go to the top of the gauge, the odo should start adding a little mileage and the fuel should go to 1/2 of a tank.
If the wires are good, you should keep looking for a good cluster. I have tried several things to fix one from hitting solder joints to baking the board. A lot of wasted time. I'm about to start trying to figure out if it is possible to get a '98 cluster to work and just upgrade the thing since the fit.
polskamafia mjl
Finding a working used cluster is probably my best option, I agree. I'm going to try soldering the old cluster on the off chance that it actually works. I've got nothing to lose.
Ben850
Been thanked: 7 times
Post by Ben850 »
polskamafia mjl wrote:Finding a working used cluster is probably my best option, I agree. I'm going to try soldering the old cluster on the off chance that it actually works. I've got nothing to lose.
Let me know how you figure this one out M.
I have two other turbo clusters in my storage, but I still have to pull the one from my T-5R to change its odometer gear.
Since it was in an accident, I may be changing other parts in that area as well.
To further my frustration, I have to discern the wiring for the Viper alarm/remote start/anti-theft...
It is a complicated wiring issue that the previous owner had no paperwork to help with.
That is my problem, I digress.
I have extra clusters and parts. Let me know M. I might be of help.
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
polskamafia mjl
I soldered the broken connector but, alas, no luck.
Ben850 wrote: I have extra clusters and parts. Let me know M. I might be of help.
OMG yes please!! :D
