1998 S70 T5 -- 280mm 288mm same thing?
mar601
Year and Model: 1998
Has thanked: 34 times
Been thanked: 5 times
Post by mar601 »
I see some brake kits, even some listed on the same web page (https://www.fcpeuro.com/Volvo-parts/S70 ... =213&e=152) that say 280mm and some listings that say 288mm.
I have a 98 S70 T5 -- can I get either 280 or 288 -- are they referring to the same thing?
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
They are different and you need to replace things in sets. You can't mix and match calipers and rotors between the two sizes. If you are just looking to replace parts you need to match what you have.
mar601
Post by mar601 »
I don't intend to -- I want to buy a brake kit (all 4 wheels) but the 280 and 288 throw me -- they must mean the same thing after all only 8mm
woolshire
Year and Model: C70 HPT Vert 2002
Post by woolshire »
They are NOT the same thing. Your calipers will not fit, at least properly, if you get the wrong ones.
db130
Year and Model: 2002 V70 T5
Post by db130 »
If you look at the contents of their "288MMBK4" kit, it mentions that it comes with Brembo 09556821 rotors which is a 280mm rotor
I think it's a misnamed kit and they are essentially the same thing.
The real question is, if you have a '98 S70 T5, why *wouldn't* you go for the 302mm rotors?
2002 V70 T5 169k
2002 V70 NA 249k
2006 Mini Cooper S 90k
Has thanked: 2199 times
Been thanked: 1852 times
Just to clarify, you only need the larger front caliper bracket to fit the larger rotors. You use the same caliper and the rest of the stuff, the bracket allows the caliper to sit at a wider point.
