1998 Volvo s70 t5 water in exhaust
Nickkniffin
- Year and Model: 1998 s70
Ok I have a volvo that the head gasket blew and we replaced but since then there has been white smoke in exhaust,smoke in dipstick and some oil has accumulated in top of the engine under the spark plug cover what could be the reason and how could it be tested and fixed
- dosbricks
- Year and Model: '96 855, '98 S70
- Been thanked: 4 times
Welcome to the forum, Nick. Unfortunately, white smoke in exhaust is often coolant. Do a compression test on the engine and see if all the cylinders test similar, which would be good news. Smoke from the dipstick is often a stopped up PCV system which could account for oil leaking from the filler gasket or PCV hose atop the engine.
- Has thanked: 2199 times
Water in the muffler could be residue from the head-gasket issue getting trapped and condensing in the muffler system. Once you have done the other suggested tests, take the car for a good long run to allow the muffler system to dry out. Also, if you tend to do a lot of short journeys, the muffler system doesn't always get hot enough to expel condensation that forms in the muffler system as it cools.
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Sometimes the motor is overheated so bad that it is shot.
Compression test will tell.
- 12 Replies
- 7524 Views
Last post by viper69
- 5014 Views
Last post by kallekula
- 5132 Views
Last post by darrylrobert
- 33 Replies
- 9432 Views
Last post by misha
- 2101 Views
Last post by dosbricks
