I'm in the middle of a front pad & rotor replacement on the '01 S40.
Struggled, but eventually got the rusty disk off the left side.
The right side disk is being stubborn. I first sprayed with PB Blaster; pounded around the hub portion with a hammer; tried threading bolts through the threaded holes that are in the disk (to facilitate easy removal, not!) but those stripped and lastly tried a large gear puller that grabbed from the outside of the disk. None of those worked.
I saw some youtube videos that used a bolt through the caliper mount holes to push the back side of the rotor. I may end up using that method, but am concerned about bending the ears that the caliper mounts to. Anyone ever use that method? How did it work?
The other method I was going to try is less conventional. Here's what I'm thinking...
Remove the wheel, reinstall the lug nuts all the way till they bottom out on the rotor and then back them off a half turn; lower the car so the brake disk rests on a block of wood; roll the car back and forth and hopefully the rusted bond will release. What do you think? Bad idea?
I've heard of something like this to release rusted rims and thought it may work for the rotor.
2001 S40 Rusted brake disk removal
- alschnertz
- Year and Model: 1995 854T
- Has thanked: 2 times
- Been thanked: 12 times
'84 Prelude
'06 MPV
'13 Ford Focus SE
'84 Prelude
'06 MPV
'13 Ford Focus SE
Livens
- Year and Model: 2003 S40
I've had stuck rotors on other cars and here is a trick that always works for me. Get a propane torch and heat up the hub section of the rotor, then give it a good whack with the biggest hammer you've got. I have a 5 lb. sledge that works great for this sort of thing.
- alschnertz
You're right, and I forgot to mention that I did the heat too to no avail.
I'm a little reluctant to pound the heck out of it. I don't want to ruin anything else.
I guess it would be wise to remove the ABS sensor before pounding it.
For now, I still want to try rolling it on a block of wood.
'84 Prelude
'06 MPV
'13 Ford Focus SE
'84 Prelude
'06 MPV
'13 Ford Focus SE
- instarx
- Year and Model: XC70 T6 2011
- Has thanked: 1 time
Maybe this is a little obvious, but you did remove the wheel locator pin(s), right?
2011 XC70 T6 - current
2017 Alfa Romeo Giulia Q2 - Totaled in 2022. Not my fault.
2011 XC60 - sold
2000 V70XC - given to a friend, wish I still had it.
2011 XC60 - sold
- alschnertz
This '01 S40 does not have locating pins like a 700 or 850.
Maybe others did, but those are the only other two that I'm familiar with.
Obvious yes, but thanks for trying.
'84 Prelude
'06 MPV
'13 Ford Focus SE
'84 Prelude
'06 MPV
'13 Ford Focus SE
Livens
I have 'heard' that you can crack the cage inside of CV joints by hitting them too hard straight on, but from the side or on the rotor edge you should be fine.alschnertz wrote:You're right, and I forgot to mention that I did the heat too to no avail.
As a final resort... know anyone with an angle grinder
Good luck and let us know how you make out.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Get a piece of solid wood, and force it between the upper disk side and a part of the spindle. Hammer the wood downwards.
- alschnertz
Well, rolling the disk on a block of wood did nothing.
So I resorted to using a couple of bolts through the caliper mounting holes.
It worked fine and I was done in a half hour.
Here's a youtube video of the procedure. It's not on a Volvo, but it worked the same.
'84 Prelude
'06 MPV
'13 Ford Focus SE
'84 Prelude
'06 MPV
'13 Ford Focus SE
- 944 Views
Last post by Charsiufan
- 12 Replies
- 4545 Views
Last post by theWIFES_S70
- 16 Replies
- 8055 Views
Last post by matthew1
- 1492 Views
- 1382 Views
Last post by E Showell
