Hi guys, I have been a lurker for sometime now… And tonight I took the plunge and created an account.
My problem is on a 2004 v70 2.5 turbo. Great car, well cared for, and clean. 120k miles. Recently it has developed a ever so slight misfire that trips the check engine light. The difficulty is that it only happens when the car is cold. It is hardly audible and can really only be heard at the tail pipe with a slight "putt putt" sound that's barely out of rhythm . Once warmed up it runs perfectly with no hesitation and no hint of a misfire whatsoever. No loss of power, perfect sound, Etc.
I am a decent mechanic and handle most issues myself. Things I have done so far in chasing this issue is I stared with replacing the plugs with authentic volvo it's. This help the issue and definitely smoothed the car out as the plugs needed to be done, but to no avail. The misfire continued. Next, I replaced all the coil packs. Again this smoothed everything out and helped a ton but the misfire continue the next day. I searched for a vacuum leak, but found none. I figured it was on schedule to have the PCV system checked so I replaced it with a full kit from IPD. I found a fair amount of cunk in the bottom port of the oil box, I cleaned it all out and the car sounds like it breaths better (probably in my head) ... But still the cel came back on. Misfire cylinder 2!!
My question is this, before I dig in and start looking at the head and the valves, is there a possibility that there is a computer or ignition system that needs to be reprogrammed (flashed?) and updated? It's a long shot I know. I looked for pinch the wires and I found none.
This misfire is starting to give me a headache! Thanks everyone.
2004 v70 misfire cylinder 2
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Another relatively easy & inexpensive check is to remove and flow test the injector in cyl #2. Other than that, maybe it has a small head gasket leak or an issue with the valves.
draser
- Year and Model: 2005 S60 2.5T
- Been thanked: 2 times
After all that maintenance you did it really sonds like it's a cyl 2 problem - I'd read the spark plugs, especially if you still have old ones, to see if #2 looks different. If it's smoked it's too much gas, white deposits it's coolant, etc.
2005 Volvo S60 2.5T, Zimmerman/Akebono brakes
2012 Honda Accord, EBC slotted rotors
richard baumann
- Year and Model: s60r 2004
I chased a misfire on cyl #2 in my 2004 R for 35,000 km, did the plugs, did the coil packs. I finally took it to a local independent Volvo shop that had the correct software to see that the misfire was only there on a COLD start up and that the #2 injector was holding open when cold and flooding the cylinder. There was a short puff puff noise from the exhaust when cold.
I got a set of injectors from IPD and all has be fine for the last 50,000 km.
- 2859 Views
- 16 Replies
- 4442 Views
Last post by shiloh51933
- 41 Replies
- 7796 Views
Last post by Kniftyg0d
- 1311 Views
Last post by mrscullini
- 19 Replies
- 3325 Views
