My mystery issue with stalling returned this past weekend. Noticed a bit of hesitation upon shifting into reverse, then drive. Drove a short distance back home and the car stalled just as I was pulling into my driveway (how convenient). Started the car the next day, noticed slightly rough idle and CEL light was on. I ran the codes and got 1-2-1 - faulty MAF sensor. Was able to reset the CEL, but have not driven it since then. The previous owner replaced the MAF with an OE Bosch brand new one before I purchased the car last October.
I cleaned the throttle body and IACV a few months ago as a preventative given the similar previous symptoms, but did not get to the MAF. Advice please - Should I clean the MAF with CRC cleaner and see if that helps? Would code 1-2-1 come up for any other reason? Thanks.
1994 850 Wagon (Base) - Code 1-2-1, Stalling Issue
- Year and Model: Many Volvos
- Been thanked: 76 times
It could be a cruddy connector. Does the car smooth out when you unplug the MAF sensor altogether?
If the car runs better with the MAF unplugged then it is likely bad.
jjs70pdx
- Year and Model: 2000 Volvo S70 AWD
Hi Lee,
I haven't tried that yet. Just tried starting it with MAF plugged in and it stalled within about 30 seconds. So unplug the connector to the MAF and restart to see if the rough idle/stall discontinues?
Correct. The car will run all day without the MAF but it won't run great. The throttle response will be weird and the mileage will stink but it is a good test for a bad MAF sensor.
Are you getting any codes from port A-6? Without the MAF the ECU substitutes values from the other sensors to make fuel decisions and if one of those sensors is also messed up it won't run at all.
jjs70pdx
Any help on what else I can troubleshoot would be much appreciated. Car engine is cranking but not starting at all now. I have no codes to read since I cleared them before it wouldn't start and just have 1-1-1 all around now from A2 and A6.
- 465 Views
Last post by jreed
- 2119 Views
Last post by SonicAdventure
- 1768 Views
Last post by Cbruns850
- 17 Replies
- 4852 Views
- 7666 Views
Last post by enriquepr21
